Einleitung
This step-by- step process demonstrates how to replace a dead or dying battery on your Acer Aspire 3000. It is important to follow the steps carefully in order to prevent damage to the battery ports upon removal. Damage to the ports may cause a bad connection with a replacement battery. Use caution to always remove the battery whenever you are repairing parts of your device.
Begin with the device face down.
Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
Slide the button found below the battery to the left into the unlocked position.
Locate the battery and the tab to the right of it.
Pull the tab to the right while simultaneously pushing the battery away from you.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
