Zum Hauptinhalt wechseln
Acer Aspire 3000 RAM Replacement
Was du brauchst
  1. Acer Aspire 3000 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Begin with the device face down.
    • Orient the laptop so that the battery is on the side opposite of you and the headphone ports are facing towards you.
  2. Acer Aspire 3000 RAM Replacement: Schritt 2, Bild 1 von 2 Acer Aspire 3000 RAM Replacement: Schritt 2, Bild 2 von 2
    • Slide the button found below the battery to the left into the unlocked position.
    • You will know the battery is unlocked if the tab is pushed to the side where the symbol is unlocked.
  3. Acer Aspire 3000 RAM Replacement: Schritt 3, Bild 1 von 2 Acer Aspire 3000 RAM Replacement: Schritt 3, Bild 2 von 2
    • Locate the battery and the tab to the right of it.
    • Pull the tab to the right while simultaneously pushing the battery away from you.
    • Make sure you push the battery only when tab is held in the right position in order to avoid damage to the device.
  4. Acer Aspire 3000 RAM Replacement, RAM: Schritt 4, Bild 1 von 1
    • Unscrew the two 4.6 mm Phillips #1 screws found at the bottom of the RAM cover using the phillips head j1 bit.
  5. Acer Aspire 3000 RAM Replacement: Schritt 5, Bild 1 von 1
    • Open the RAM cover by wedging the opening tool and the metal spudger in the opening between the two screws.
  6. Acer Aspire 3000 RAM Replacement: Schritt 6, Bild 1 von 1
    • Slide the opening tool around the sides of the cover to release the 3 tabs that hold the cover down.
  7. Acer Aspire 3000 RAM Replacement: Schritt 7, Bild 1 von 1
    • Lift and pull the cover back towards you to detach it from the device.
  8. Acer Aspire 3000 RAM Replacement: Schritt 8, Bild 1 von 1
    • Push the white tabs on either side away from the from the chip.
    • The chip should be released upward automatically after pushing the tabs.
  9. Acer Aspire 3000 RAM Replacement: Schritt 9, Bild 1 von 1
    • Pull and lift the chip to release it from the RAM port.
  10. Acer Aspire 3000 RAM Replacement: Schritt 10, Bild 1 von 1
    • Repeat step 9 to release the bottom chip from its RAM port.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
roro6730
351 Reputation
2 Anleitungen geschrieben
Baylor, Team 4-2, Williams Fall 2016 Mitglied von Baylor, Team 4-2, Williams Fall 2016
BU-WILLIAMS-F16S4G2
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 10
Insgesamt: 684
