Einleitung
In this guide, you will be instructed on how to replace the battery in your laptop. The battery allows for your laptop’s mobility feature, as it keeps the laptop powered on while disconnected from an outlet.
This replacement is not difficult and will take you no more than a minute to complete. It requires no tools, and can be completed in 3 steps.
Turn the Acer Aspire 3003WLCi so that the bottom of the laptop is facing up. Orient it so that the battery is on your left.
There will be two switches on the back of the laptop: one at the top of the battery, and one at the bottom.
Shift the bottom switch into an upward position in order to unlock the battery.
To unlock the upper switch, forcefully push the switch up and hold it in this position.
While holding the upper switch in the upward position, remove the battery by pulling it out to the left.
