Einleitung
In this guide, you will be instructed on how to replace the hard drive in your laptop. Your hard drive acts as a long-term memory for your computer, and the greater your hard drive’s capacity, the more work you can store on your computer.
This replacement is not difficult and will take you no more than five minutes to complete. It requires very few tools, and can be completed in 4 steps.
Was du brauchst
Turn the Acer Aspire 3003WLCi so that the bottom of the laptop is facing up. Orient it so that the battery is on your left.
There will be two switches on the back of the laptop: one at the top of the battery, and one at the bottom.
Shift the bottom switch into an upward position in order to unlock the battery.
To unlock the upper switch, forcefully push the switch up and hold it in this position.
While holding the upper switch in the upward position, remove the battery by pulling it out to the left.
Locate the hard drive access panel in the upper right corner of the laptop.
Using a Phillips #0 screwdriver, unscrew the two 5mm captive screws attached to the access panel.
The hard drive is connected to the computer; simply pull it back from the connector and take it out of the laptop casing.
