Zum Hauptinhalt wechseln
Acer Aspire 4520-5464 CD/DVD Drive Replacement
Was du brauchst
  1. Acer Aspire 4520-5464 CD/DVD Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Shut down the computer and disconnect all external devices and cables.
    • Flip the computer over.
  2. Acer Aspire 4520-5464 CD/DVD Drive Replacement: Schritt 2, Bild 1 von 2 Acer Aspire 4520-5464 CD/DVD Drive Replacement: Schritt 2, Bild 2 von 2
    • Ensure that the battery compartment lock tab is in the unlocked position.
    • Slide the sliding black tab away from the battery compartment.
    • The inside edge of the battery should be released, causing it to slightly pop out of the compartment.
  3. Acer Aspire 4520-5464 CD/DVD Drive Replacement: Schritt 3, Bild 1 von 1
    • Grasp the inside edge of the battery and lift to fully detach the battery from the computer.
  4. Acer Aspire 4520-5464 CD/DVD Drive Replacement, CD/DVD Drive: Schritt 4, Bild 1 von 3 Acer Aspire 4520-5464 CD/DVD Drive Replacement, CD/DVD Drive: Schritt 4, Bild 2 von 3 Acer Aspire 4520-5464 CD/DVD Drive Replacement, CD/DVD Drive: Schritt 4, Bild 3 von 3
    • Remove 7 of the 2mm Phillips #1 screw from the largest panel on back of the laptop
    • Lift up the panel from the indent located on the right side.
  5. Acer Aspire 4520-5464 CD/DVD Drive Replacement: Schritt 5, Bild 1 von 1
    • Remove the .5mm Phillips #1 black screw located on the left side of the panel opening.
  6. Acer Aspire 4520-5464 CD/DVD Drive Replacement: Schritt 6, Bild 1 von 2 Acer Aspire 4520-5464 CD/DVD Drive Replacement: Schritt 6, Bild 2 von 2
    • Using the screwdriver, push the CD drive out of the laptop through the panel exposure.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Washington State, Team S5-G117, Phelps-Hillen Fall 2017 Mitglied von Washington State, Team S5-G117, Phelps-Hillen Fall 2017
WSU-PHELPS-HILLEN-F17S5G117
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 410
