Zum Hauptinhalt wechseln
Acer Aspire 4741G-332G32Mn Motherboard Replacement
Was du brauchst
  1. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the lock latch to unlock battery.
  2. Acer Aspire 4741G-332G32Mn Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Slide the middle latch and remove the battery.
  3. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Backplate: Schritt 3, Bild 1 von 3 Acer Aspire 4741G-332G32Mn Motherboard Replacement, Backplate: Schritt 3, Bild 2 von 3 Acer Aspire 4741G-332G32Mn Motherboard Replacement, Backplate: Schritt 3, Bild 3 von 3
    • Pry off the keyboard using the opening tool.
    • Remove the two screws that are connected to the motherboard using a Phillips #0 screwdriver.
  4. Acer Aspire 4741G-332G32Mn Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove all 12 screws from the backplate using a Phillips #0 screwdriver.
  5. Acer Aspire 4741G-332G32Mn Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Using the prying tool to remove the bottom of the laptop.
  6. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Fan: Schritt 6, Bild 1 von 2 Acer Aspire 4741G-332G32Mn Motherboard Replacement, Fan: Schritt 6, Bild 2 von 2
    • Using a Phillips #0 screwdriver, remove the eight screws that hold the motherboard to the frame of the laptop.
    • Disconnect the USB port from the motherboard.
  7. Acer Aspire 4741G-332G32Mn Motherboard Replacement: Schritt 7, Bild 1 von 2 Acer Aspire 4741G-332G32Mn Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Unscrew the 6 screws that hold the fan to the motherboard using the same screwdriver.
  8. Acer Aspire 4741G-332G32Mn Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 1
    • Remove the motherboard from the device.
Abschluss
UMass Dartmouth, Team S2-G6, Simcock Spring 2019 Mitglied von UMass Dartmouth, Team S2-G6, Simcock Spring 2019
UMASSD-SIMCOCK-S19S2G6
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 33
Insgesamt: 1,676
