Einleitung
If your keyboard has issues and/or doesn't function properly, use this guide to replace it with a new one.
Was du brauchst
Remove the two 6.0 mm screws that secure the keyboard using a Phillips head screwdriver.
Turn the laptop over and open it.
Use flat edged tools to gently separate the keyboard from the laptop. It should snap off with a small amount of force.
Gently lift away the keyboard, making sure not to damage the data cable or the connector.
Remove piece of tape that covers the connection between the data cable and the connector.
Detach the data cable by flipping up the small black latch on the connector.
Once the latch is lifted, the keyboard should be completely free.
3 weitere Personen haben diese Anleitung absolviert.
