Zum Hauptinhalt wechseln
Acer Aspire 4743-6481 Ram Card Replacement
Was du brauchst
  1. Acer Aspire 4743-6481 Ram Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn over the laptop to view the underside.
  2. Acer Aspire 4743-6481 Ram Card Replacement: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers (or a similar tool) to slide the orange push pin. To release the battery, push it to the left.
  3. Acer Aspire 4743-6481 Ram Card Replacement: Schritt 3, Bild 1 von 1
    • You can lift the battery up and out now.
  4. Acer Aspire 4743-6481 Ram Card Replacement, RAM Card: Schritt 4, Bild 1 von 1
    • Remove three 7.0 mm screws with a Phillips head screwdriver from the back panel to gain access to the RAM cards.
  5. Acer Aspire 4743-6481 Ram Card Replacement: Schritt 5, Bild 1 von 1
    • Place the device with the battery side facing up, as shown on the picture.
    • After removing the back panel, you will see the RAM cards located to the right.
  6. Acer Aspire 4743-6481 Ram Card Replacement: Schritt 6, Bild 1 von 1
    • You should notice a silver tab on each side of the RAM card. Push each tab away at the same time to detach the card.
  7. Acer Aspire 4743-6481 Ram Card Replacement: Schritt 7, Bild 1 von 1
    • If done successfully, the RAM should pop out and you can lift it out with no effort.
Abschluss
AL-Moatasem
101 Reputation
1 Anleitung geschrieben
USF Tampa, Team S5-G1, Lacy Spring 2017 Mitglied von USF Tampa, Team S5-G1, Lacy Spring 2017
USFT-LACY-S17S5G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 720
