Zum Hauptinhalt wechseln
Acer Aspire 4810TZ-4120 Keyboard Replacement
Was du brauchst
  1. Acer Aspire 4810TZ-4120 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 3 Acer Aspire 4810TZ-4120 Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 3 Acer Aspire 4810TZ-4120 Keyboard Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Locate the five (5) tabs at the top of the keyboard that are holding it in place
    • The 2nd and 3rd pictures are close ups of the tabs
  2. Acer Aspire 4810TZ-4120 Keyboard Replacement: Schritt 2, Bild 1 von 2 Acer Aspire 4810TZ-4120 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • The first picture shows the notches in the keyboard that the tabs to into to hold it in place. You cannot see these until the keyboard is removed
    • Insert the flat part of the Spudger tool into one of the holes in front of the tab
    • Push the tab back so it is no longer holding the keyboard.
    • Repeat this step for all of the tabs
  3. Acer Aspire 4810TZ-4120 Keyboard Replacement: Schritt 3, Bild 1 von 2 Acer Aspire 4810TZ-4120 Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Lay the keyboard upside down
    • Remove any tape that is on the connector with tweezers
    • Gently remove the connector that is on the ribbon cable from the back of the keyboard
    • Your keyboard is now ready to be replaced with a new one
Abschluss
Maria Saavedra
257 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 9
Letzte 30 Tage: 19
Insgesamt: 517
