Zum Hauptinhalt wechseln
Acer Aspire 5100 Keyboard Replacement
Was du brauchst
  1. Acer Aspire 5100 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 2 Acer Aspire 5100 Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Open and push the screen back all the way until it is horizontal with the rest of the laptop.
    • Use an opening tool to remove the panel above the keyboard that has the power button on it.
    • After you have released the tabs, lift up the panel.
  2. Acer Aspire 5100 Keyboard Replacement: Schritt 2, Bild 1 von 3 Acer Aspire 5100 Keyboard Replacement: Schritt 2, Bild 2 von 3 Acer Aspire 5100 Keyboard Replacement: Schritt 2, Bild 3 von 3
    • Under the panel, remove the two screws that connect the keyboard to the laptop.
    • One screw is located above the F5 button, and the other one is located above the F10 button.
    • Potential for device damage: Lift up the keyboard CAREFULLY because there is a ribbon that connects the keyboard to the motherboard.
  3. Acer Aspire 5100 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Release the catch on the ribbon socket by sliding the two tabs toward the ribbon.
    • Pull the ribbon under the keyboard to detach it from the motherboard.
    • Remove the keyboard.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Brad Rollinson
1.113 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 14-39, Forte Fall 2010 Mitglied von Cal Poly, Team 14-39, Forte Fall 2010
CPSU-FORTE-F10S14G39
5 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
this step is missing steo 0 : before you lift the panel, remove 3 screw that hold the panel
Rifqi Khairur Rahman - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 9
Insgesamt: 13,268
