Zum Hauptinhalt wechseln
Acer Aspire 5251-1513 Hard Drive Replacement
Was du brauchst
  1. Acer Aspire 5251-1513 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn over the laptop so the back is facing up.
  2. Acer Aspire 5251-1513 Hard Drive Replacement: Schritt 2, Bild 1 von 2 Acer Aspire 5251-1513 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Next to the battery is a switch with a lock symbol on it.
    • Unlock the switch by sliding it to reveal a red unlock symbol.
  3. Acer Aspire 5251-1513 Hard Drive Replacement: Schritt 3, Bild 1 von 2 Acer Aspire 5251-1513 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Pull the other switch completely while the red unlock symbol is still present. The battery pack should pop up a bit.
  4. Acer Aspire 5251-1513 Hard Drive Replacement: Schritt 4, Bild 1 von 2 Acer Aspire 5251-1513 Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Remove the battery pack via the indentation at the top of the battery in between the two switches.
  5. Acer Aspire 5251-1513 Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 1
    • Unscrew the two 8.6 mm screws using a Phillips #0 screwdriver.
  6. Acer Aspire 5251-1513 Hard Drive Replacement: Schritt 6, Bild 1 von 2 Acer Aspire 5251-1513 Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Use a spudger or plastic opening tool to lift the panel up. Then remove the panel entirely with your hands.
  7. Acer Aspire 5251-1513 Hard Drive Replacement: Schritt 7, Bild 1 von 2 Acer Aspire 5251-1513 Hard Drive Replacement: Schritt 7, Bild 2 von 2
    • Slide the hard drive to the left until it clicks and then pull it out completely.
  8. Acer Aspire 5251-1513 Hard Drive Replacement: Schritt 8, Bild 1 von 3 Acer Aspire 5251-1513 Hard Drive Replacement: Schritt 8, Bild 2 von 3 Acer Aspire 5251-1513 Hard Drive Replacement: Schritt 8, Bild 3 von 3
    • Unscrew the four 3.6 mm screws on either side of the casing with the Phillips #0 screwdriver.
    • Remove the hard drive out of its casing.
    • Be Gentle with the hard rive, only touch the edges.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Gicely Rodriguez
1.029 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S1-G6, Leahy Spring 2019 Mitglied von USF Tampa, Team S1-G6, Leahy Spring 2019
USFT-LEAHY-S19S1G6
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 571
