Zum Hauptinhalt wechseln
Acer Aspire 5251-1513 RAM Replacement
Was du brauchst
  1. Acer Aspire 5251-1513 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn over the laptop so the back is facing up.
  2. Acer Aspire 5251-1513 RAM Replacement: Schritt 2, Bild 1 von 2 Acer Aspire 5251-1513 RAM Replacement: Schritt 2, Bild 2 von 2
    • Next to the battery is a switch with a lock symbol on it.
    • Unlock the switch by sliding it to reveal a red unlock symbol.
  3. Acer Aspire 5251-1513 RAM Replacement: Schritt 3, Bild 1 von 2 Acer Aspire 5251-1513 RAM Replacement: Schritt 3, Bild 2 von 2
    • Pull the other switch completely while the red unlock symbol is still present. The battery pack should pop up a bit.
  4. Acer Aspire 5251-1513 RAM Replacement: Schritt 4, Bild 1 von 2 Acer Aspire 5251-1513 RAM Replacement: Schritt 4, Bild 2 von 2
    • Remove the battery pack via the indentation at the top of the battery in between the two switches.
  5. Acer Aspire 5251-1513 RAM Replacement, RAM: Schritt 5, Bild 1 von 1
    • Unscrew the two 8.6 mm screws using a Phillips #0 screwdriver.
  6. Acer Aspire 5251-1513 RAM Replacement: Schritt 6, Bild 1 von 1
    • Use a spudger or plastic opening tool to lift the panel up. Then remove the panel entirely with your hands.
  7. Acer Aspire 5251-1513 RAM Replacement: Schritt 7, Bild 1 von 3 Acer Aspire 5251-1513 RAM Replacement: Schritt 7, Bild 2 von 3 Acer Aspire 5251-1513 RAM Replacement: Schritt 7, Bild 3 von 3
    • Find two metal pieces on either side of the RAM.
    • Pull the two tabs apart. The RAM will pop up when released.
  8. Acer Aspire 5251-1513 RAM Replacement: Schritt 8, Bild 1 von 1
    • Gently pull the RAM out
    • Please be careful pulling out the RAM, only touch the edges.
    • Repeat step 8 & 9 for the second RAM piece if applicable.
Abschluss
Gicely Rodriguez
1.029 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S1-G6, Leahy Spring 2019 Mitglied von USF Tampa, Team S1-G6, Leahy Spring 2019
USFT-LEAHY-S19S1G6
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 736
