Zum Hauptinhalt wechseln
Acer Aspire 5253 Hard Drive Replacement
Was du brauchst
  1. Acer Aspire 5253 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop over.
  2. Acer Aspire 5253 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
  3. Acer Aspire 5253 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
  4. Acer Aspire 5253 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
  5. Acer Aspire 5253 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • You have successfully removed the battery. Congratulations!
  6. Acer Aspire 5253 Hard Drive Replacement, Back Cover Panel: Schritt 6, Bild 1 von 1
    • Now, locate the two screws that hold the back cover panel onto the laptop.
  7. Acer Aspire 5253 Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Unscrew both of the screws that are holding the back panel in place with the Philips #00 head.
    • The screws are 3/8" in length and have a 1/4" head.
  8. Acer Aspire 5253 Hard Drive Replacement: Schritt 8, Bild 1 von 2 Acer Aspire 5253 Hard Drive Replacement: Schritt 8, Bild 2 von 2
    • Once both screws have been removed use a plastic opening tool to lift the panel up. Starting with the indented notch , and moving left and right from there.
  9. Acer Aspire 5253 Hard Drive Replacement: Schritt 9, Bild 1 von 1
    • After the panel has been loosened by the plastic opening tool, take your finger, place it in the gap, and remove the panel from the laptop.
  10. Acer Aspire 5253 Hard Drive Replacement, Hard Drive: Schritt 10, Bild 1 von 1
    • Once the cover panel is off, locate the hard drive.
  11. Acer Aspire 5253 Hard Drive Replacement: Schritt 11, Bild 1 von 2 Acer Aspire 5253 Hard Drive Replacement: Schritt 11, Bild 2 von 2
    • Locate the two screws that are holding the hard drive in place.
  12. Acer Aspire 5253 Hard Drive Replacement: Schritt 12, Bild 1 von 1
    • Remove the two screws using a Phillips #00 screw driver.
  13. Acer Aspire 5253 Hard Drive Replacement: Schritt 13, Bild 1 von 1
    • Carefully slide the hard drive in the opposite direction of where the screws are located until it dislocates.
  14. Acer Aspire 5253 Hard Drive Replacement: Schritt 14, Bild 1 von 1
    • Pull the hard drive out of its compartment.
Abschluss
9 weitere Personen haben diese Anleitung absolviert.
Cynthia Barajas
2.195 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 8-11, Regan Spring 2014 Mitglied von Cal Poly, Team 8-11, Regan Spring 2014
CPSU-REGAN-S14S8G11
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 42
Insgesamt: 7,430
