Zum Hauptinhalt wechseln
Acer Aspire 5253 Optical Drive Replacement
Was du brauchst
  1. Acer Aspire 5253 Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop over.
    Frag FixBot
    Kommentar hinzufügen
  2. Acer Aspire 5253 Optical Drive Replacement: Schritt 2, Bild 1 von 1
    • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
    Frag FixBot
  3. Acer Aspire 5253 Optical Drive Replacement: Schritt 3, Bild 1 von 1
    • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
    Frag FixBot
  4. Acer Aspire 5253 Optical Drive Replacement: Schritt 4, Bild 1 von 1
    • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
    Frag FixBot
  5. Acer Aspire 5253 Optical Drive Replacement: Schritt 5, Bild 1 von 1
    • You have successfully removed the battery. Congratulations!
    Frag FixBot
  6. Acer Aspire 5253 Optical Drive Replacement, Optical Drive: Schritt 6, Bild 1 von 1
    • Turn the computer over and locate the screw that is in between the battery and cover panel as shown in the picture.
    Frag FixBot
  7. Acer Aspire 5253 Optical Drive Replacement: Schritt 7, Bild 1 von 1
    • Remove the screw with a Phillips #00 screw driver.
    • The screw is 3/8" in length and has a 1/4" head.
    Frag FixBot
  8. Acer Aspire 5253 Optical Drive Replacement: Schritt 8, Bild 1 von 1
    • Carefully pry the optical drive loose.
    Frag FixBot
  9. Acer Aspire 5253 Optical Drive Replacement: Schritt 9, Bild 1 von 2 Acer Aspire 5253 Optical Drive Replacement: Schritt 9, Bild 2 von 2
    • Slowly remove the optical drive.
    Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 8-11, Regan Spring 2014 Mitglied von Cal Poly, Team 8-11, Regan Spring 2014
CPSU-REGAN-S14S8G11
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 42
Insgesamt: 7,180
