Zum Hauptinhalt wechseln
Acer Aspire 5253 RAM Replacement
Was du brauchst
  1. Acer Aspire 5253 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop over.
    Frag FixBot
    Kommentar hinzufügen
  2. Acer Aspire 5253 RAM Replacement: Schritt 2, Bild 1 von 1
    • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
    Frag FixBot
  3. Acer Aspire 5253 RAM Replacement: Schritt 3, Bild 1 von 1
    • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
    Frag FixBot
  4. Acer Aspire 5253 RAM Replacement: Schritt 4, Bild 1 von 1
    • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
    Frag FixBot
  5. Acer Aspire 5253 RAM Replacement: Schritt 5, Bild 1 von 1
    • You have successfully removed the battery. Congratulations!
    Frag FixBot
  6. Acer Aspire 5253 RAM Replacement, Back Cover Panel: Schritt 6, Bild 1 von 1
    • Now, locate the two screws that hold the back cover panel onto the laptop.
    Frag FixBot
  7. Acer Aspire 5253 RAM Replacement: Schritt 7, Bild 1 von 1
    • Unscrew both of the screws that are holding the back panel in place with the Philips #00 head.
    • The screws are 3/8" in length and have a 1/4" head.
    Frag FixBot
  8. Acer Aspire 5253 RAM Replacement: Schritt 8, Bild 1 von 2 Acer Aspire 5253 RAM Replacement: Schritt 8, Bild 2 von 2
    • Once both screws have been removed use a plastic opening tool to lift the panel up. Starting with the indented notch , and moving left and right from there.
    Frag FixBot
  9. Acer Aspire 5253 RAM Replacement: Schritt 9, Bild 1 von 1
    • After the panel has been loosened by the plastic opening tool, take your finger, place it in the gap, and remove the panel from the laptop.
    Frag FixBot
  10. Acer Aspire 5253 RAM Replacement, RAM: Schritt 10, Bild 1 von 1
    • Now, locate the RAM.
    Frag FixBot
  11. Acer Aspire 5253 RAM Replacement: Schritt 11, Bild 1 von 1
    • Locate the two metal pieces on both sides of the RAM that are holding it in place.
    Frag FixBot
  12. Acer Aspire 5253 RAM Replacement: Schritt 12, Bild 1 von 1
    • Pull the tabs apart to remove the RAM.
    • The RAM will pop up once they are pried open.
    Frag FixBot
  13. Acer Aspire 5253 RAM Replacement: Schritt 13, Bild 1 von 2 Acer Aspire 5253 RAM Replacement: Schritt 13, Bild 2 von 2
    • Carefully slide the RAM out of the compartment.
    Frag FixBot
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 8-11, Regan Spring 2014 Mitglied von Cal Poly, Team 8-11, Regan Spring 2014
CPSU-REGAN-S14S8G11
4 Mitglieder
15 Anleitungen geschrieben
1 Kommentar zur Anleitung
which bus-ram acer 5253 can use? i know it use bus 1066 but i don't know with bus 1666 how is machine active?
nhanblack1996 - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 52
Insgesamt: 4,511
