Einleitung
Does your Acer Aspire 5349-2592 get stuck at a blue screen during bootup, regularly crash or freeze? Does your computer slow down the longer it is in use, or act sluggish when running programs? If so, a ram memory problem might exist, and replacement might be necessary. This guide provides simple steps with minimal tools to replace the ram memory module.
If you are unsure the ram memory is bad, review the Troubleshooting Computer Memory guide located on iFixit’s website at the following URL before proceeding: ++Troubleshooting Computer Memory
Please make sure to follow the prerequisite procedures.
Was du brauchst
Now that the Acer-Aspire 5349-2592 laptop battery is unlocked, press the battery release button down.
Holding down the laptop battery release button, gently pull the battery away from the laptop.
Remove all of the screws located on the back of the laptop using your Phillips #0 screwdriver.
Pry open the backplate using the iFixit opening tool and remove the backplate from the device.
Eine weitere Person hat diese Anleitung absolviert.
