Zum Hauptinhalt wechseln
Acer Aspire 5534-1096 Battery Replacement
  1. Acer Aspire 5534-1096 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Disconnect laptop from electric source prior to any repair.
    • On the bottom side of the laptop, you will unlock the safety lock by sliding it towards the left.
  2. Acer Aspire 5534-1096 Battery Replacement: Schritt 2, Bild 1 von 1
    • Now, you'll hold this latch to the left. Everything is unlatched. The battery should feel free.
  3. Acer Aspire 5534-1096 Battery Replacement: Schritt 3, Bild 1 von 3 Acer Aspire 5534-1096 Battery Replacement: Schritt 3, Bild 2 von 3 Acer Aspire 5534-1096 Battery Replacement: Schritt 3, Bild 3 von 3
    • While continuing to hold the latch in the open position, use your other hand to push the battery away from the device to remove it.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 315
