Zum Hauptinhalt wechseln
Acer Aspire 5534-1096 CD Drive Replacement
Was du brauchst
  1. Acer Aspire 5534-1096 CD Drive Replacement, CD Drive: Schritt 1, Bild 1 von 1
    • Unscrew the two 4.8mm Phillips #00 screws.
    • These two screws will not completely be unfastened because they are technically bolts.
  2. Acer Aspire 5534-1096 CD Drive Replacement: Schritt 2, Bild 1 von 1
    • Use a spudger to pry open the access panel.
  3. Acer Aspire 5534-1096 CD Drive Replacement: Schritt 3, Bild 1 von 1
    • Remove the single 1mm Phillips #00 screw.
  4. Acer Aspire 5534-1096 CD Drive Replacement: Schritt 4, Bild 1 von 3 Acer Aspire 5534-1096 CD Drive Replacement: Schritt 4, Bild 2 von 3 Acer Aspire 5534-1096 CD Drive Replacement: Schritt 4, Bild 3 von 3
    • Use the spudger to release the CD drive by placing it between the lip of the drive and the rest of the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 144
