Einleitung
“Wireless fidelity” chips, or WiFi, are utilized to gain access to a “wireless access network”, or WAN. It is uncommon for this component needing to be repaired, however, common reason may be you want to upgrade your broadband connection internet speed. You could always check your internet speed online. This guide will demonstrate how to replace the Wi-Fi chip in the Acer Aspire 5534-1096.
Was du brauchst
Remove the Phillips #00 screw from the upper right corner of the Wi-Fi chip.
Using the tweezers, disconnect the black and white wires.
