Einleitung
Battery replacement is a simple replacement, it can be successfully done in 5 minutes. Before beginning the replacement, it is important to have unplugged the power cord.
Was du brauchst
Make sure your device is unplugged from the power source . Gently turn it over, and lay it on a flat on its face.
This latch locks your battery in place, it should always be locked with the exception of replacement. Slide it horizontally to the unlock position.
Locate the latch that ejects the battery (top right corner) and push it to the left, so the battery can come out.
Push the battery forward and it will slide out, it should come out with ease. There should be a label with the part number.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
