Zum Hauptinhalt wechseln
Acer Aspire 5534-1146 Hard Drive Replacement
Was du brauchst
  1. Acer Aspire 5534-1146 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Locate where the hard drive is located on the back side of the laptop and unscrew the two .8cm Long screws.
  2. Acer Aspire 5534-1146 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Once you have have removed the back panel cover, find the hard drive’s location.
  3. Acer Aspire 5534-1146 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Find and locate the two screws that are 0.8cm long that are holding the hard drive in place to the back metal plate.
    • Carefully take a PH #0 screwdriver and remove the two screws.
  4. Acer Aspire 5534-1146 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Once you have unscrewed the two screws, carefully slide the hard drive the opposite direction of the screws that you just removed, slide the drive till it is free.
    • You are now ready to remove the hard drive from it’s compartment from the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 477
