Einleitung
This repair guide will give you a step-by-step procedure on how to replace the screen on your Acer Aspire 5534-1146 device.
Was du brauchst
Use the blue spudger to remove the 4 rubber supports from each corner of the screen.
After use a PH0 screw bit to remove the corresponding screws underneath.
Use a plastic opening tool to carefully release the plastic clips that hold the plastic frame to the back cover.
Remove the 4 screws in the corners underneath the plastic frame that was removed. Screen should then be able to come of the frame.
Take the screen lay it face down on top of the keyboard.
Unplug the cable that is connected to the video card.
Remove the tape, and unplug the display cable on the back of the screen.
Pull the tape off of the cable from the back of the screen, and now the screen should be free to come off. You are now ready to install a new one.
