Was du brauchst
Remove the 4 rubber supports from the screen. Then remove the screws underneath.
With a spudger, release the clips that hold the plastic frame to the back cover.
Be careful while handling the bottom part, specially with the hinges, as there are cables inside.
Unstick the cables from the back of the LCD screen.
The LCD should be completely free, so just take it out and install a new one.
8 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Hi there.. I just bought a display for my aspire 5536 and it seems it has a different fitting for the cable.. in fact I bought an LED display and the original one was an LCD (there is an inverter fitted in the lid under the screen) ok.. my question.. Is that possible under any circumstances to fit this new LED screen in my laptop by changing the video cable with a proper one for this new screen??
