Zum Hauptinhalt wechseln
Acer Aspire 5740-5780 Battery Replacement
  1. Acer Aspire 5740-5780 Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Aspire 5740-5780 Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Unlock the battery by flipping a switch near the release latch.
  2. Acer Aspire 5740-5780 Battery Replacement: Schritt 2, Bild 1 von 1
    • Slide the release latch to the left to release the battery from the PC.
  3. Acer Aspire 5740-5780 Battery Replacement: Schritt 3, Bild 1 von 2 Acer Aspire 5740-5780 Battery Replacement: Schritt 3, Bild 2 von 2
    • Use your hands to pry the battery free of the computer.
Abschluss
Gian Farrell
639 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team S3-G6, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S3-G6, Peak Spring 2018
UMASSD-PEAK-S18S3G6
3 Mitglieder
9 Anleitungen geschrieben
Ein Kommentar
Hi,
i have acer aspire 5740 which was running gine but suddenly went off and never turned back on. I tried 30 seconds holding power button procedure too but when i plugged the charger in the light flashes every 3 seconds . Could you please help me out to turn it back on because i got very important documents saved in.
regards
Umar - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 493
