Zum Hauptinhalt wechseln
Acer Aspire 5740-5780 WLAN Module Replacement
Was du brauchst
  1. Achtung: Die Schritte 1-4 stammen von einer Anleitung, die derzeit bearbeitet wird.
    Acer Aspire 5740-5780 WLAN Module Replacement, Prepare Acer Aspire 5740-5780 for Disassembly: Schritt 1, Bild 1 von 2 Acer Aspire 5740-5780 WLAN Module Replacement, Prepare Acer Aspire 5740-5780 for Disassembly: Schritt 1, Bild 2 von 2
    • Turn the laptop off and remove the power cord.
  2. Acer Aspire 5740-5780 WLAN Module Replacement: Schritt 2, Bild 1 von 2 Acer Aspire 5740-5780 WLAN Module Replacement: Schritt 2, Bild 2 von 2
    • Press in the SD Card or the SD Card Dummy if no SD Card is there. Remove card when it pops out.
  3. Acer Aspire 5740-5780 WLAN Module Replacement: Schritt 3, Bild 1 von 1
    • Flip the laptop over on its face, so that the back is showing.
  4. Acer Aspire 5740-5780 WLAN Module Replacement: Schritt 4, Bild 1 von 1
    • Put grounding strap on one of your wrists and attach the other end to a large metal object (recommended method).
    • If you don't have a grounding strap an alternative approach is to touch a metal object that is either large or connected to the earth. Then avoid doing things that would accumulate static electricity on your body.
    • Touching the internals of your device while you aren't grounded could destroy your laptop.
  5. Acer Aspire 5740-5780 WLAN Module Replacement, Battery: Schritt 5, Bild 1 von 2 Acer Aspire 5740-5780 WLAN Module Replacement, Battery: Schritt 5, Bild 2 von 2
    • Unlock the battery by flipping a switch near the release latch.
  6. Acer Aspire 5740-5780 WLAN Module Replacement: Schritt 6, Bild 1 von 1
    • Slide the release latch to the left to release the battery from the PC.
  7. Acer Aspire 5740-5780 WLAN Module Replacement: Schritt 7, Bild 1 von 2 Acer Aspire 5740-5780 WLAN Module Replacement: Schritt 7, Bild 2 von 2
    • Use your hands to pry the battery free of the computer.
  8. Acer Aspire 5740-5780 WLAN Module Replacement, Back Cover: Schritt 8, Bild 1 von 2 Acer Aspire 5740-5780 WLAN Module Replacement, Back Cover: Schritt 8, Bild 2 von 2
    • Unscrew the 2 captive screws and 3 M2.5 x L8 screws holding back cover in place.
  9. Acer Aspire 5740-5780 WLAN Module Replacement: Schritt 9, Bild 1 von 2 Acer Aspire 5740-5780 WLAN Module Replacement: Schritt 9, Bild 2 von 2
    • Use spudger to pry open the back panel.
    • Then lift panel off of the computer.
  10. Acer Aspire 5740-5780 WLAN Module Replacement, Hard Drive: Schritt 10, Bild 1 von 1
    • Remove the one M2 x L4 screw that secures the hard drive in place.
    • Screw not shown in picture.
  11. Acer Aspire 5740-5780 WLAN Module Replacement: Schritt 11, Bild 1 von 1
    • Using an opening tool or your hands, slide the hard drive out of its connector.
  12. Acer Aspire 5740-5780 WLAN Module Replacement: Schritt 12, Bild 1 von 1
    • Lift the hard drive out of the computer.
  13. Acer Aspire 5740-5780 WLAN Module Replacement, WLAN Module: Schritt 13, Bild 1 von 1
    • Disconnect the black and white antenna cables from the module.
    • Cables not shown.
  14. Acer Aspire 5740-5780 WLAN Module Replacement: Schritt 14, Bild 1 von 2 Acer Aspire 5740-5780 WLAN Module Replacement: Schritt 14, Bild 2 von 2
    • Remove one M2 x L4 screw, which is securing the WLAN Module.
  15. Acer Aspire 5740-5780 WLAN Module Replacement: Schritt 15, Bild 1 von 1
    • Carefully remove the module from the system, using plastic opening tools.
Abschluss
Gian Farrell
639 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team S3-G6, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S3-G6, Peak Spring 2018
UMASSD-PEAK-S18S3G6
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 371
