Zum Hauptinhalt wechseln
Acer Aspire 5740-6378 WiFi Card Replacement
Was du brauchst
  1. Acer Aspire 5740-6378 WiFi Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the locking switch into the unlocked position to ready the battery for removal.
  2. Acer Aspire 5740-6378 WiFi Card Replacement: Schritt 2, Bild 1 von 1
    • Slide the release latch until the battery pops out.
  3. Acer Aspire 5740-6378 WiFi Card Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery now that it's been unsecured.
  4. Acer Aspire 5740-6378 WiFi Card Replacement, WiFi Card: Schritt 4, Bild 1 von 1
    • Flip over the device so the back is facing upward.
  5. Acer Aspire 5740-6378 WiFi Card Replacement: Schritt 5, Bild 1 von 2 Acer Aspire 5740-6378 WiFi Card Replacement: Schritt 5, Bild 2 von 2
    • Remove the five 8.7mm Phillips #0 screws securing the back panel.
  6. Acer Aspire 5740-6378 WiFi Card Replacement: Schritt 6, Bild 1 von 2 Acer Aspire 5740-6378 WiFi Card Replacement: Schritt 6, Bild 2 von 2
    • Use the black spudger to pry open the back panel.
  7. Acer Aspire 5740-6378 WiFi Card Replacement: Schritt 7, Bild 1 von 2 Acer Aspire 5740-6378 WiFi Card Replacement: Schritt 7, Bild 2 von 2
    • The WiFi card should be directly above the hard drive. Detach the two coaxial connectors attached to the WiFi card by pulling on them.
  8. Acer Aspire 5740-6378 WiFi Card Replacement: Schritt 8, Bild 1 von 1
    • Remove the two 3mm Phillips #0 screws securing the WiFi card.
  9. Acer Aspire 5740-6378 WiFi Card Replacement: Schritt 9, Bild 1 von 1
    • Remove the WiFi card.
Abschluss
Ian Rodriguez
734 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S2-G5, Bailey Spring 2019 Mitglied von UMass Dartmouth, Team S2-G5, Bailey Spring 2019
UMASSD-BAILEY-S19S2G5
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 491
