Zum Hauptinhalt wechseln
Acer Aspire 5742 CMOS Battery Replacement
Was du brauchst
  1. Acer Aspire 5742 CMOS Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Acer Aspire 5742 CMOS Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Acer Aspire 5742 CMOS Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 CMOS Battery Replacement, Cover Panel: Schritt 2, Bild 1 von 3 Acer Aspire 5742 CMOS Battery Replacement, Cover Panel: Schritt 2, Bild 2 von 3 Acer Aspire 5742 CMOS Battery Replacement, Cover Panel: Schritt 2, Bild 3 von 3
    • Turn the notebook around to face you.
    • There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
  3. Acer Aspire 5742 CMOS Battery Replacement: Schritt 3, Bild 1 von 3 Acer Aspire 5742 CMOS Battery Replacement: Schritt 3, Bild 2 von 3 Acer Aspire 5742 CMOS Battery Replacement: Schritt 3, Bild 3 von 3
    • Use a spudger to release the panel from the plastic retaining clips keeping it in place.
    • Do not apply too much force, or you may break the clips.
    • Remove the panel and set it aside.
  4. Acer Aspire 5742 CMOS Battery Replacement, CMOS Battery: Schritt 4, Bild 1 von 2 Acer Aspire 5742 CMOS Battery Replacement, CMOS Battery: Schritt 4, Bild 2 von 2
    • After removing the cover panel, you will see the hard drive, the RAM, and the CMOS battery.
    • The CMOS battery is the silver coin-like object in the center.
  5. Acer Aspire 5742 CMOS Battery Replacement: Schritt 5, Bild 1 von 3 Acer Aspire 5742 CMOS Battery Replacement: Schritt 5, Bild 2 von 3 Acer Aspire 5742 CMOS Battery Replacement: Schritt 5, Bild 3 von 3
    • Press the tip of the spudger underneath the CMOS battery with very slight force.
    • Press down on the opposite side of the battery while prying the battery upward with the spudger.
    • After the battery is mostly lifted from the slot, you may pull out the battery with your fingers.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Bill Murray
581 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 2-6, Isaacson Fall 2016 Mitglied von UMass Dartmouth, Team 2-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G6
3 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 26
Letzte 30 Tage: 107
Insgesamt: 14,174
