Einleitung
Just as simple as it gets! to work on a laptop, well there you have the Acer Aspire 5742G and the easiest job to change memory sticks!
Was du brauchst
Einführungsvideo
click here for video
Make sure your computer is off and remove the battery with the security tabs shown in the picture
Then from the dented tab, either your finger, card or spudger will work, and start prying GENTLY!
Easily work your way around.
Now put the new memory stick in!
When it is in, then gently push it downwards to lock it in place!
2 weitere Personen haben diese Anleitung absolviert.
