Einleitung
The battery to the laptop will need to be removed for most repair to the laptop in order to prevent electrical shock. The battery is designed to be easily and quickly removed from the laptop by sliding a switch and pulling the battery free. You'll need to have the laptop powered off, and unplugged before attempting to remove the battery. Wait ten minutes after unplugging and powering off to ensure there is no left over charge.
Was du brauchst
Using a small tool such as tweezers or a pen, slide the orange switch completely to the left to unlock the battery.
While holding the orange switch in place, lift the battery by the lip and pull it away from the laptop.
2 weitere Personen haben diese Anleitung absolviert.
