Einleitung
The optical drive is where CDs and DVDs are inserted and read in a laptop. Optical drives have various moving parts so they can malfunction or stop working properly. The optical drive can be removed easily in order to replace it.
Was du brauchst
Using a small tool such as tweezers or a pen, slide the orange switch completely to the left to unlock the battery.
While holding the orange switch in place, lift the battery by the lip and pull it away from the laptop.
Locate the black screw just above the battery.
Remove the black screw holding the optical drive in place by using a Phillips #0 screwdriver.
