Einleitung
The goal of this guide is to help replace the hard drive of your Acer Aspire 5750-6677. People replace their hard drives in order to have a new one with better capacity and performance capabilities. Hard drives need to be replaced in three to four years in order to prevent them from failing. The hard drive’s purpose is to store any data, pictures, music, videos and any files created or downloaded. This replacement process is considered to be easy and will only take around eight minutes. There are no special skills required and the only tool you will need is a Phillips #0 screwdriver.
Was du brauchst
Flip the device over so the backside is facing up.
Remove the two screws with the Phillips #0 screwdriver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
