Zum Hauptinhalt wechseln
Acer Aspire 5750-6677 Motherboard Replacement
Was du brauchst
  1. Acer Aspire 5750-6677 Motherboard Replacement, Battery Replacement: Schritt 1, Bild 1 von 1
    • Flip the laptop over.
  2. Acer Aspire 5750-6677 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Place a screw driver in the orange tab then slide to the right.
  3. Acer Aspire 5750-6677 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Lift and remove the battery.
  4. Acer Aspire 5750-6677 Motherboard Replacement, Hard Drive: Schritt 4, Bild 1 von 2 Acer Aspire 5750-6677 Motherboard Replacement, Hard Drive: Schritt 4, Bild 2 von 2
    • Flip the device over so the backside is facing up.
    • Remove the two screws with the Phillips #0 screwdriver.
  5. Acer Aspire 5750-6677 Motherboard Replacement: Schritt 5, Bild 1 von 2 Acer Aspire 5750-6677 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the cover to access the hard drive.
  6. Acer Aspire 5750-6677 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Using the Phillips #0, remove the two screws holding the hard drive in.
  7. Acer Aspire 5750-6677 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Pull the tab and lift up to remove the hard drive.
  8. Acer Aspire 5750-6677 Motherboard Replacement, Motherboard: Schritt 8, Bild 1 von 2 Acer Aspire 5750-6677 Motherboard Replacement, Motherboard: Schritt 8, Bild 2 von 2
    • Start by flipping the device over to expose the screws.
    • Remove ten screws with the Phillips #0 screwdriver.
  9. Acer Aspire 5750-6677 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove the four screws found under the battery.
  10. Acer Aspire 5750-6677 Motherboard Replacement: Schritt 10, Bild 1 von 2 Acer Aspire 5750-6677 Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Flip the laptop back around so the Acer logo is facing upwards.
    • Open the laptop and using the iFixit opening tool, press the tabs in at the very top of the keyboard, in order to remove the keyboard.
  11. Acer Aspire 5750-6677 Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Use the Phillips #0 screwdriver to remove six screws.
    • Pull the top off of the keyboard to expose the motherboard.
  12. Acer Aspire 5750-6677 Motherboard Replacement: Schritt 12, Bild 1 von 3 Acer Aspire 5750-6677 Motherboard Replacement: Schritt 12, Bild 2 von 3 Acer Aspire 5750-6677 Motherboard Replacement: Schritt 12, Bild 3 von 3
    • Remove the seven screws using the Phillips #0 screwdriver.
    • Detach any wires or cables that are attached to the motherboard.
    • Remove the motherboard.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Dean Smith
207 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S1-G3, Valliere Fall 2019 Mitglied von UMass Dartmouth, Team S1-G3, Valliere Fall 2019
UMASSD-VALLIERE-F19S1G3
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 37
Insgesamt: 1,763
