Einleitung
This guide will show you ho to remove the optical disk drive, usually a CD or DVD reader and/or writer. You might need to do this if it is malfunctioning and needs to be replace, or if you are upgrading to a better one.
Was du brauchst
Make sure the device is unplugged and completely powered down.
Turn the device over.
The lock switch can slide either towards or away from the battery. If it is pushed towards the battery, the release switch is locked and the battery can not be released.
Slide the switch away from the battery.
The battery release switch is just to the inside of the battery and slides parallel to it.
Push the switch to the side. It is not just an open or close switch, it actually pops the battery up so you will feel some resistance.
Using a Phillips #1 screwdriver, remove the 7mm screw holding the drive.
