Zum Hauptinhalt wechseln
Acer Aspire 7736Z-4809 Back Panel Removal
Was du brauchst
  1. Acer Aspire 7736Z-4809 Back Panel Removal, Acer Aspire 7736Z-4809 Repair Preparation: Schritt 1, Bild 1 von 1
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 Back Panel Removal: Schritt 2, Bild 1 von 1
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 Back Panel Removal, Back Panel: Schritt 3, Bild 1 von 2 Acer Aspire 7736Z-4809 Back Panel Removal, Back Panel: Schritt 3, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  4. Acer Aspire 7736Z-4809 Back Panel Removal: Schritt 4, Bild 1 von 3 Acer Aspire 7736Z-4809 Back Panel Removal: Schritt 4, Bild 2 von 3 Acer Aspire 7736Z-4809 Back Panel Removal: Schritt 4, Bild 3 von 3
    • Remove the back panel of the laptop.
  5. Acer Aspire 7736Z-4809 Back Panel Removal: Schritt 5, Bild 1 von 1
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
Abschluss
UC Davis, Team 2-4, Oliver Fall 2016 Mitglied von UC Davis, Team 2-4, Oliver Fall 2016
UCD-OLIVER-F16S2G4
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 525
