Einleitung
To remove the CPU cooling fan for replacement, we must disassemble the laptop and deal with sensitive electrical components. Please carefully follow these procedures.
Was du brauchst
Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
Use tweezers to remove the fan cable from its slot.
Use the Phillips #1 screwdriver to unscrew the four Phillips #1 screws that connect the cooling fan from the panel.
2 weitere Personen haben diese Anleitung absolviert.
