Zum Hauptinhalt wechseln
Acer Aspire 7736Z-4809 CPU Fan Replacement
Was du brauchst
  1. Acer Aspire 7736Z-4809 CPU Fan Replacement, Acer Aspire 7736Z-4809 Repair Preparation: Schritt 1, Bild 1 von 1
    • Unplug and power off the laptop.
    • If the battery is still connected to the laptop, remove the battery.
  2. Acer Aspire 7736Z-4809 CPU Fan Replacement: Schritt 2, Bild 1 von 1
    • Flip over the laptop so that the back panel of the laptop is facing up.
  3. Acer Aspire 7736Z-4809 CPU Fan Replacement, Back Panel: Schritt 3, Bild 1 von 2 Acer Aspire 7736Z-4809 CPU Fan Replacement, Back Panel: Schritt 3, Bild 2 von 2
    • Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
    • Only the four screws in the center are removable, the four along the edges are held in by rivets but can be loosened.
  4. Acer Aspire 7736Z-4809 CPU Fan Replacement: Schritt 4, Bild 1 von 3 Acer Aspire 7736Z-4809 CPU Fan Replacement: Schritt 4, Bild 2 von 3 Acer Aspire 7736Z-4809 CPU Fan Replacement: Schritt 4, Bild 3 von 3
    • Remove the back panel of the laptop.
  5. Acer Aspire 7736Z-4809 CPU Fan Replacement: Schritt 5, Bild 1 von 1
    • Connect a grounding cord to a metal interface on the laptop.
    • Ground the laptop to prevent static electricity from damaging the electrical components inside the laptop.
  6. Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: Schritt 6, Bild 1 von 3 Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: Schritt 6, Bild 2 von 3 Acer Aspire 7736Z-4809 CPU Fan Replacement, CPU Fan: Schritt 6, Bild 3 von 3
    • Use tweezers to remove the fan cable from its slot.
    • The cables consist of red, black, and yellow wires.
  7. Acer Aspire 7736Z-4809 CPU Fan Replacement: Schritt 7, Bild 1 von 2 Acer Aspire 7736Z-4809 CPU Fan Replacement: Schritt 7, Bild 2 von 2
    • Use the Phillips #1 screwdriver to unscrew the four Phillips #1 screws that connect the cooling fan from the panel.
    • These screws are held in the unit via springs. You cannot remove them. They can only be loosened.
  8. Acer Aspire 7736Z-4809 CPU Fan Replacement: Schritt 8, Bild 1 von 3 Acer Aspire 7736Z-4809 CPU Fan Replacement: Schritt 8, Bild 2 von 3 Acer Aspire 7736Z-4809 CPU Fan Replacement: Schritt 8, Bild 3 von 3
    • Carefully remove the cooling fan from the motherboard.
    • Slightly lift up the fan, gradually slide it towards you and then fully remove it from the case.
  9. Acer Aspire 7736Z-4809 CPU Fan Replacement: Schritt 9, Bild 1 von 1
    • Install the modified or new cooling fan.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
UC Davis, Team 2-4, Oliver Fall 2016 Mitglied von UC Davis, Team 2-4, Oliver Fall 2016
UCD-OLIVER-F16S2G4
5 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
You’ll need some thermal compound when reinstalling for the heat syncs under the copper tube.
Minks - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 782
