Einleitung
This replacement requires opening up the laptop. Please follow the procedures carefully.
Was du brauchst
Use the Phillips #1 screwdriver to remove the three 4.5mm Phillips #1 screws.
Orient the laptop so that the hinges between the LCD module and the laptop's bottom base are visible.
Use the plastic opening tools to separate the speaker panel from the laptop.
Flip over the LCD module of the laptop.
Repeat this step with the other side of the laptop.
Gently hold the speaker panel by the sides and pull upwards to release the panel.
Use the flat end of the medium sized metal spudger tool to release the two tabs at the top of the keyboard.
Insert a finger into the opening above the F11 key and pry the keyboard until it is released from the casing.
Eine weitere Person hat diese Anleitung absolviert.
