Einleitung
Before replacing or upgrading the RAM, make sure that the replacement RAM is compatible with the laptop. Acer Aspire 7736Z-4809 supports the DDR2 667MHz memory,240-pin soDIMM RAM with the capacity of up to 2GB.
Was du brauchst
Use the Phillips #1 screwdriver to remove the eight 6.5 mm Phillips #1 screws.
2 Kommentare
Not only is it 200-pin soDIMM module instead of a 240-pin soDIMM module, it's a pc2-6400 (800MHz) and not a pc2-5300 (667MHz).
