Zum Hauptinhalt wechseln
Acer Aspire 774G-58GS Thermal Paste Replacement
Was du brauchst
  1. Acer Aspire 774G-58GS Thermal Paste Replacement, Thermal Paste: Schritt 1, Bild 1 von 3 Acer Aspire 774G-58GS Thermal Paste Replacement, Thermal Paste: Schritt 1, Bild 2 von 3 Acer Aspire 774G-58GS Thermal Paste Replacement, Thermal Paste: Schritt 1, Bild 3 von 3
    • Remove the three screws from the plate that covers the RAM and HDD using a Phillips #0 screwdriver.
    • Remove the plate from the laptop.
  2. Acer Aspire 774G-58GS Thermal Paste Replacement: Schritt 2, Bild 1 von 2 Acer Aspire 774G-58GS Thermal Paste Replacement: Schritt 2, Bild 2 von 2
    • Remove the DVD drive and the three screws that are underneath it.
    • Remove all the screws surrounding the backplate.
  3. Acer Aspire 774G-58GS Thermal Paste Replacement: Schritt 3, Bild 1 von 3 Acer Aspire 774G-58GS Thermal Paste Replacement: Schritt 3, Bild 2 von 3 Acer Aspire 774G-58GS Thermal Paste Replacement: Schritt 3, Bild 3 von 3
    • Disconnect the speaker wire beneath the RAM.
    • Gently remove the backplate from the laptop.
  4. Acer Aspire 774G-58GS Thermal Paste Replacement: Schritt 4, Bild 1 von 2 Acer Aspire 774G-58GS Thermal Paste Replacement: Schritt 4, Bild 2 von 2
    • Remove the five screws from the heat sink.
    • Take a cotton ball and dab it with isopropyl alcohol.
    • Use the cotton ball to wipe the old thermal paste from the heat sink.
  5. Acer Aspire 774G-58GS Thermal Paste Replacement: Schritt 5, Bild 1 von 3 Acer Aspire 774G-58GS Thermal Paste Replacement: Schritt 5, Bild 2 von 3 Acer Aspire 774G-58GS Thermal Paste Replacement: Schritt 5, Bild 3 von 3
    • Take another cotton ball, dab it with isopropyl alcohol, and gently wipe the thermal paste off of the GPU and CPU.
    • There is no need to rub hard as it should come off with ease.
    • Once the thermal paste is completely off, let the heat sink dry for a couple of minutes.
    • Apply a dab of new thermal paste in the middle of the CPU and GPU.
    • Corsair TM30 thermal paste is used in this guide.
  6. Acer Aspire 774G-58GS Thermal Paste Replacement: Schritt 6, Bild 1 von 1
    • Put the heatsink back on and screw it in place.
Abschluss
Abdul Munam Khan
133 Reputation
1 Anleitung geschrieben
York University, Team 1-12, O'Regan Winter 2022 Mitglied von York University, Team 1-12, O'Regan Winter 2022
YORK-O'REGAN-W22S1G12
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 27
Insgesamt: 641
