Zum Hauptinhalt wechseln
Acer Aspire 8735G Battery Replacement
Was du brauchst
  1. Acer Aspire 8735G Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before proceeding, power down your Laptop and remove the power cable.
    • Close the display and lay it on a flat surface, top-side down.
  2. Acer Aspire 8735G Battery Replacement: Schritt 2, Bild 1 von 1
    • Unlock the battery by sliding the battery lock to the unlock part.
  3. Acer Aspire 8735G Battery Replacement: Schritt 3, Bild 1 von 1
    • Slide the middle lock to the right and the battery will pop up.
  4. Acer Aspire 8735G Battery Replacement: Schritt 4, Bild 1 von 1
    • If you want to replace the battery and nothing else then now is the time to do so.
    • Once the battery hatch is unlocked you can now safely remove the battery.
Abschluss
Regome
767 Reputation
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 70
