Zum Hauptinhalt wechseln
Einleitung
This guide walks you through the proper steps to disconnect and remove the battery from the Laptop.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device. Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device.
    • Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device.
  2. Lift the back panel using a plastic opening tool.  Slowly make your way around the device until the back panel comes off. Lift the back panel using a plastic opening tool.  Slowly make your way around the device until the back panel comes off. Lift the back panel using a plastic opening tool.  Slowly make your way around the device until the back panel comes off.
    • Lift the back panel using a plastic opening tool. Slowly make your way around the device until the back panel comes off.
  3. Press and hold the small black button located on the motherboard just above the battery for five seconds. Press and hold the small black button located on the motherboard just above the battery for five seconds.
    • Press and hold the small black button located on the motherboard just above the battery for five seconds.
  4. Using two plastic opening tools tightly grab the connector going from the battery to the motherboard and pull to unplug. Using two plastic opening tools tightly grab the connector going from the battery to the motherboard and pull to unplug. Using two plastic opening tools tightly grab the connector going from the battery to the motherboard and pull to unplug.
    • Using two plastic opening tools tightly grab the connector going from the battery to the motherboard and pull to unplug.
  5. Unscrew two 6.2 mm Phillips #1 screws on the right and left sides of the battery. Unscrew two 6.2 mm Phillips #1 screws on the right and left sides of the battery. Unscrew two 6.2 mm Phillips #1 screws on the right and left sides of the battery.
    • Unscrew two 6.2 mm Phillips #1 screws on the right and left sides of the battery.
  6. Carefully remove the battery by lifting it out of the casing.
    • Carefully remove the battery by lifting it out of the casing.
Abschluss
7 weitere Nutzer haben diese Anleitung absolviert.
USF Tampa, Team 16-1, Blackwell Winter 2016 Mitglied von USF Tampa, Team 16-1, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G1
4 Mitglieder
11 Anleitungen geschrieben
4 Kommentare
Excellent instructions, very precise and easy to follow. Great job!!!!
[deleted] - Antwort
Can I remove the battery and use only the ac adapter to power it? Will it work and not cause damage to the unit?
json_viray - Antwort
when you take the battery out it works ok and when you put the battery the orange light when take out the battery its fine could it be the battery or board connector
steve varney - Antwort
when battery is out it works fine when connect out and orange and blue light come on then no display remove battery every returns to normal
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 6
Letzten 7 Tage: 15
Letzten 30 Tage: 50
Insgesamt: 9,739
