Einleitung
This guide will walk you through the process of replacing the back panel on an Acer Aspire E 11.
Was du brauchst
Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device.
Lift the back panel using a plastic opening tool. Slowly make your way around the device until the back panel comes off.
Eine weitere Person hat diese Anleitung absolviert.
