Zum Hauptinhalt wechseln
Einleitung
This guide will walk you through the process of replacing the motherboard on an Acer Aspire E 11.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device. Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device.
    • Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device.
  2. Lift the back panel using a plastic opening tool.  Slowly make your way around the device until the back panel comes off. Lift the back panel using a plastic opening tool.  Slowly make your way around the device until the back panel comes off. Lift the back panel using a plastic opening tool.  Slowly make your way around the device until the back panel comes off.
    • Lift the back panel using a plastic opening tool. Slowly make your way around the device until the back panel comes off.
  3. Press and hold the small black button located on the motherboard just above the battery for five seconds. Press and hold the small black button located on the motherboard just above the battery for five seconds.
    • Press and hold the small black button located on the motherboard just above the battery for five seconds.
  4. Using two plastic opening tools tightly grab the connector going from the battery to the motherboard and pull to unplug. Using two plastic opening tools tightly grab the connector going from the battery to the motherboard and pull to unplug. Using two plastic opening tools tightly grab the connector going from the battery to the motherboard and pull to unplug.
    • Using two plastic opening tools tightly grab the connector going from the battery to the motherboard and pull to unplug.
  5. Unscrew two 6.2 mm Phillips #1 screws on the right and left sides of the battery. Unscrew two 6.2 mm Phillips #1 screws on the right and left sides of the battery. Unscrew two 6.2 mm Phillips #1 screws on the right and left sides of the battery.
    • Unscrew two 6.2 mm Phillips #1 screws on the right and left sides of the battery.
  6. Carefully remove the battery by lifting it out of the casing.
    • Carefully remove the battery by lifting it out of the casing.
  7. Locate the keyboard cable on the motherboard.  Using, two plastic opening tools on each side of the connector, pull the two gray tabs outward and then remove the cable from the motherboard. Locate the keyboard cable on the motherboard.  Using, two plastic opening tools on each side of the connector, pull the two gray tabs outward and then remove the cable from the motherboard. Locate the keyboard cable on the motherboard.  Using, two plastic opening tools on each side of the connector, pull the two gray tabs outward and then remove the cable from the motherboard.
    • Locate the keyboard cable on the motherboard. Using, two plastic opening tools on each side of the connector, pull the two gray tabs outward and then remove the cable from the motherboard.
  8. Use a plastic opening tool to carefully lift the white hinge up on the touchpad cable connector, and gently remove the cable from the motherboard. Use a plastic opening tool to carefully lift the white hinge up on the touchpad cable connector, and gently remove the cable from the motherboard. Use a plastic opening tool to carefully lift the white hinge up on the touchpad cable connector, and gently remove the cable from the motherboard.
    • Use a plastic opening tool to carefully lift the white hinge up on the touchpad cable connector, and gently remove the cable from the motherboard.
  9. Use two plastic opening tools to grip each side of the connector for the speaker cable and gently pull the cable from the motherboard. Use two plastic opening tools to grip each side of the connector for the speaker cable and gently pull the cable from the motherboard. Use two plastic opening tools to grip each side of the connector for the speaker cable and gently pull the cable from the motherboard.
    • Use two plastic opening tools to grip each side of the connector for the speaker cable and gently pull the cable from the motherboard.
  10. Remove the tape on the connector for the display cable. Use two plastic opening tools to grip each side of the connector and gently pull the display cable from the motherboard. Use two plastic opening tools to grip each side of the connector and gently pull the display cable from the motherboard.
    • Remove the tape on the connector for the display cable.
    • Use two plastic opening tools to grip each side of the connector and gently pull the display cable from the motherboard.
  11. Remove one 6.2 mm Phillips #1 screw from the wireless chip on the left side of the motherboard. Remove one 6.2 mm Phillips #1 screw from the wireless chip on the left side of the motherboard.
    • Remove one 6.2 mm Phillips #1 screw from the wireless chip on the left side of the motherboard.
  12. Remove three 6.2 mm Phillips #1 screws that attach the motherboard to the laptop casing. Remove three 6.2 mm Phillips #1 screws that attach the motherboard to the laptop casing. Remove three 6.2 mm Phillips #1 screws that attach the motherboard to the laptop casing.
    • Remove three 6.2 mm Phillips #1 screws that attach the motherboard to the laptop casing.
  13. Return to the wireless chip and gently pull it from the connector on the side of the motherboard.
    • Return to the wireless chip and gently pull it from the connector on the side of the motherboard.
  14. The motherboard can now be lifted out from the laptop casing.
    • The motherboard can now be lifted out from the laptop casing.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
USF Tampa, Team 16-1, Blackwell Winter 2016 Mitglied von USF Tampa, Team 16-1, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G1
4 Mitglieder
11 Anleitungen geschrieben
3 Kommentare
Some of the bullet points can be broken up into information points or divided into more bullet points per step. Also, make sure the exposure is high enough to make all parts visible
Jaie Hillery - Antwort
Hello, What is WiFi+BT card model ? Is it Atheros?
Da K - Antwort
Me podrían decir cual es el modelo de la pila del BIOS de este modelo e11 , por favor
Jesus Quiroz - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 5
Letzten 7 Tage: 16
Letzten 30 Tage: 35
Insgesamt: 4,424
