Zum Hauptinhalt wechseln
Acer Aspire E1-470P-6659 Motherboard Replacement
Was du brauchst
  1. Acer Aspire E1-470P-6659 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn off the laptop and disconnect all device cords.
  2. Acer Aspire E1-470P-6659 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Flip the laptop over so the bottom is facing you.
  3. Acer Aspire E1-470P-6659 Motherboard Replacement: Schritt 3, Bild 1 von 3 Acer Aspire E1-470P-6659 Motherboard Replacement: Schritt 3, Bild 2 von 3 Acer Aspire E1-470P-6659 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Use your finger or a spuger to pull the battery release switch.
  4. Acer Aspire E1-470P-6659 Motherboard Replacement: Schritt 4, Bild 1 von 3 Acer Aspire E1-470P-6659 Motherboard Replacement: Schritt 4, Bild 2 von 3 Acer Aspire E1-470P-6659 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Remove the battery from the laptop.
  5. Acer Aspire E1-470P-6659 Motherboard Replacement, Hard Drive: Schritt 5, Bild 1 von 2 Acer Aspire E1-470P-6659 Motherboard Replacement, Hard Drive: Schritt 5, Bild 2 von 2
    • Remove nineteen screws from the back panel using a Phillips #0 Screwdriver .
  6. Acer Aspire E1-470P-6659 Motherboard Replacement: Schritt 6, Bild 1 von 3 Acer Aspire E1-470P-6659 Motherboard Replacement: Schritt 6, Bild 2 von 3 Acer Aspire E1-470P-6659 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Run the plastic opening tool across from one corner to another along the edge.
    • Separate the keyboard panel gently.
    • Lift the keyboard slowly from the laptop but do not lift completely because there are ribbon cables attached.
  7. Acer Aspire E1-470P-6659 Motherboard Replacement: Schritt 7, Bild 1 von 2 Acer Aspire E1-470P-6659 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the two keyboard assembly ribbon cables from motherboard.
    • To release small ribbon cable, use spudger or fingers to flip gray bar along edge over.
    • To release larger ribbon cable, use pry tool or spudger to slide white plastic clip forward.
  8. Acer Aspire E1-470P-6659 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Pull up the release tab beside the hard drive.
    • Disconnect portion of ribbon cable that is covering the hard drive.
    • Handle the ribbon carefully. Do not break the metal contact.
    • While reconnecting the ribbon after replacing a new hard drive, face the blue side with a label up. Make sure the black line beside the sticker is not crooked, so that the ribbon is tight.
  9. Acer Aspire E1-470P-6659 Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Remove the hard drive screw using Phillips #0 Screwdriver.
  10. Acer Aspire E1-470P-6659 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Pull the hard drive out gently. Be aware that it is connected to the adapter.
    • Gently remove adapter by pulling on both ends simultaneously to separate it from the hard drive.
  11. Acer Aspire E1-470P-6659 Motherboard Replacement, Motherboard: Schritt 11, Bild 1 von 3 Acer Aspire E1-470P-6659 Motherboard Replacement, Motherboard: Schritt 11, Bild 2 von 3 Acer Aspire E1-470P-6659 Motherboard Replacement, Motherboard: Schritt 11, Bild 3 von 3
    • Remove additional screws that can be found on the motherboard.
    • Remove the green wifi card from motherboard.
    • Use spudger to disconnect the fan and motherboard from laptop.
  12. Acer Aspire E1-470P-6659 Motherboard Replacement: Schritt 12, Bild 1 von 2 Acer Aspire E1-470P-6659 Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Remove the cable attached to motherboard.
    • Gently lift and remove the motherboard from the laptop.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Faith Lobaton
518 Reputation
3 Anleitungen geschrieben
UC Davis, Team S4-G5, Lore Fall 2018 Mitglied von UC Davis, Team S4-G5, Lore Fall 2018
UCD-LORE-F18S4G5
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 21
Insgesamt: 1,325
