Zum Hauptinhalt wechseln
Acer Aspire E1-510-2500 Battery Replacement
Was du brauchst
  1. Acer Aspire E1-510-2500 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure that your laptop is completely switched off, and disconnected from the power source.
    • Flip the laptop so that the base of the laptop is facing up.
  2. Acer Aspire E1-510-2500 Battery Replacement: Schritt 2, Bild 1 von 2 Acer Aspire E1-510-2500 Battery Replacement: Schritt 2, Bild 2 von 2
    • Insert a spudger into the battery release latch.
    • Slide the battery release latch to the right, this will eject the battery for safe removal.
  3. Acer Aspire E1-510-2500 Battery Replacement: Schritt 3, Bild 1 von 2 Acer Aspire E1-510-2500 Battery Replacement: Schritt 3, Bild 2 von 2
    • Carefully slide the battery out of the battery's home.
Abschluss
UMass Dartmouth, Team S2-G5, Julie Fall 2017 Mitglied von UMass Dartmouth, Team S2-G5, Julie Fall 2017
UMASSD-JULIE-F17S2G5
3 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
Hello ifixit i disassembled my Acer aspire e1 laptop.....Then after i finshed assembling it.....The led light would show is charging but computer refuse to turn on...
Steve Gregg - Antwort
very nicelyexplained
Jeffrey Joseph - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 30
Insgesamt: 3,286
