Zum Hauptinhalt wechseln
Acer Aspire E1-510-2500 RAM Card Replacement
Was du brauchst
  1. Acer Aspire E1-510-2500 RAM Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure that your laptop is completely switched off, and disconnected from the power source.
    • Flip the laptop so that the base of the laptop is facing up.
  2. Acer Aspire E1-510-2500 RAM Card Replacement: Schritt 2, Bild 1 von 2 Acer Aspire E1-510-2500 RAM Card Replacement: Schritt 2, Bild 2 von 2
    • Insert a spudger into the battery release latch.
    • Slide the battery release latch to the right, this will eject the battery for safe removal.
  3. Acer Aspire E1-510-2500 RAM Card Replacement: Schritt 3, Bild 1 von 2 Acer Aspire E1-510-2500 RAM Card Replacement: Schritt 3, Bild 2 von 2
    • Carefully slide the battery out of the battery's home.
  4. Acer Aspire E1-510-2500 RAM Card Replacement, RAM Card: Schritt 4, Bild 1 von 2 Acer Aspire E1-510-2500 RAM Card Replacement, RAM Card: Schritt 4, Bild 2 von 2
    • Using a Phillips 1 screwdriver, remove the 9 mm screw which secures the back panel.
  5. Acer Aspire E1-510-2500 RAM Card Replacement: Schritt 5, Bild 1 von 2 Acer Aspire E1-510-2500 RAM Card Replacement: Schritt 5, Bild 2 von 2
    • Use a plastic opening tool to carefully pry the back panel from its home.
    • When reassembling, insert the panel from the edge opposite the screw first.
  6. Acer Aspire E1-510-2500 RAM Card Replacement: Schritt 6, Bild 1 von 3 Acer Aspire E1-510-2500 RAM Card Replacement: Schritt 6, Bild 2 von 3 Acer Aspire E1-510-2500 RAM Card Replacement: Schritt 6, Bild 3 von 3
    • Locate the tabs on either side of the RAM card.
    • Push out on both tabs simultaneously to release the RAM card.
    • The RAM card should raise slightly at the unattached edge.
  7. Acer Aspire E1-510-2500 RAM Card Replacement: Schritt 7, Bild 1 von 2 Acer Aspire E1-510-2500 RAM Card Replacement: Schritt 7, Bild 2 von 2
    • Carefully remove the RAM card from its home.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team S2-G5, Julie Fall 2017 Mitglied von UMass Dartmouth, Team S2-G5, Julie Fall 2017
UMASSD-JULIE-F17S2G5
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 16
Insgesamt: 568
