Zum Hauptinhalt wechseln
Acer Aspire E1-510P-4637 Keyboard Replacement
Was du brauchst
  1. Acer Aspire E1-510P-4637 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
  2. Acer Aspire E1-510P-4637 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Firmly grab hold of the battery and slide it out of the laptop.
  3. Acer Aspire E1-510P-4637 Keyboard Replacement, Hard Drive: Schritt 3, Bild 1 von 1
    • Remove the M2.5x8 screw with a PH1 screwdriver.
  4. Acer Aspire E1-510P-4637 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Use the plastic opening tool to pop off the small back cover.
  5. Acer Aspire E1-510P-4637 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Use a PH0 Phillips screwdriver to remove the screw securing the hard drive.
  6. Acer Aspire E1-510P-4637 Keyboard Replacement: Schritt 6, Bild 1 von 2 Acer Aspire E1-510P-4637 Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Use a nylon spudger to slightly pry up the hard drive near the screw holes.
  7. Acer Aspire E1-510P-4637 Keyboard Replacement: Schritt 7, Bild 1 von 3 Acer Aspire E1-510P-4637 Keyboard Replacement: Schritt 7, Bild 2 von 3 Acer Aspire E1-510P-4637 Keyboard Replacement: Schritt 7, Bild 3 von 3
    • Grab hold of the plastic tab and pull the hard drive away from the connectors. This will release the hard drive.
    • The hard drive connector is fragile. Handle with care.
  8. Acer Aspire E1-510P-4637 Keyboard Replacement, Keyboard: Schritt 8, Bild 1 von 1
    • Remove the fourteen M2.5x8 screws highlighted in the picture with a PH0 Phillips screwdriver.
  9. Acer Aspire E1-510P-4637 Keyboard Replacement: Schritt 9, Bild 1 von 1
    • Slide out the disk drive tray.
  10. Acer Aspire E1-510P-4637 Keyboard Replacement: Schritt 10, Bild 1 von 1
    • Use the plastic opening tool to gently pry open the laptop.
  11. Acer Aspire E1-510P-4637 Keyboard Replacement: Schritt 11, Bild 1 von 3 Acer Aspire E1-510P-4637 Keyboard Replacement: Schritt 11, Bild 2 von 3 Acer Aspire E1-510P-4637 Keyboard Replacement: Schritt 11, Bild 3 von 3
    • Rotate the back cover up a little to reveal the cables connected to the motherboard.
    • Unplug the cables by sliding them out of their receptacle.
    • The connectors are very small and fragile. Handle with care.
  12. Acer Aspire E1-510P-4637 Keyboard Replacement: Schritt 12, Bild 1 von 1
    • Remove the four center panel M1.6x3 screws with a PH0 Phillips screwdriver.
    • Remove the two M2x3 screws with a PH0 Phillips screwdriver.
  13. Acer Aspire E1-510P-4637 Keyboard Replacement: Schritt 13, Bild 1 von 3 Acer Aspire E1-510P-4637 Keyboard Replacement: Schritt 13, Bild 2 von 3 Acer Aspire E1-510P-4637 Keyboard Replacement: Schritt 13, Bild 3 von 3
    • Use the plastic opening tool to slide the metal part out to release it from the retaining tabs.
  14. Acer Aspire E1-510P-4637 Keyboard Replacement: Schritt 14, Bild 1 von 2 Acer Aspire E1-510P-4637 Keyboard Replacement: Schritt 14, Bild 2 von 2
    • Peel off the foil adhesive stuck to the keyboard.
  15. Acer Aspire E1-510P-4637 Keyboard Replacement: Schritt 15, Bild 1 von 1
    • Remove the keyboard.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 34-15, Maness Spring 2016 Mitglied von Cal Poly, Team 34-15, Maness Spring 2016
CPSU-MANESS-S16S34G15
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 1,167
