Was du brauchst
To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
Remove the plastic screw covers located near the laptop's hinge using a metal spudger.
Remove the two M2.5x8 screws highlighted in the picture with a PH0 Phillips screwdriver.
Flip the laptop over and open it up so the screen is facing up and the top of the screen is facing you.
Use a plastic opening tool to separate the the touchscreen from the back cover.
Disconnect the display cable by first taking off the tape using a metal spudger and then pulling on the black tab.
Pull back the adhesive using the metal spudger.
Pry out the camera by lifting the adhesive with the metal spudger. Then, remove the camera by lifting it up by one side.
Remove the two brackets holding the displays by unscrewing both M1 .6x3 screws with a PH0 Phillips screwdriver.
2 weitere Personen haben diese Anleitung absolviert.
