Zum Hauptinhalt wechseln
Acer Aspire E1-531-2438 Keyboard Replacement
Was du brauchst
  1. Acer Aspire E1-531-2438 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Aspire E1-531-2438 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Unplug and power down the device before removing the battery.
    • Turn the device over so the back side is facing up.
    • Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
    • Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
  2. Acer Aspire E1-531-2438 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Tilt the side of the battery closest to the orange latch upward.
    • Lift the battery up and out of the device.
  3. Acer Aspire E1-531-2438 Keyboard Replacement, Hard Drive: Schritt 3, Bild 1 von 2 Acer Aspire E1-531-2438 Keyboard Replacement, Hard Drive: Schritt 3, Bild 2 von 2
    • Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
  4. Acer Aspire E1-531-2438 Keyboard Replacement: Schritt 4, Bild 1 von 3 Acer Aspire E1-531-2438 Keyboard Replacement: Schritt 4, Bild 2 von 3 Acer Aspire E1-531-2438 Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Using the indentation, pry open the access panel with your fingers or a spudger.
    • Remove the access panel to expose the hard drive, WiFi chip, and RAM modules.
  5. Acer Aspire E1-531-2438 Keyboard Replacement: Schritt 5, Bild 1 von 3 Acer Aspire E1-531-2438 Keyboard Replacement: Schritt 5, Bild 2 von 3 Acer Aspire E1-531-2438 Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Grip the plastic tab on the hard drive, then pull to the left to unplug the drive from its socket.
    • Once free from the socket, lift the hard drive up and out of the device.
  6. Acer Aspire E1-531-2438 Keyboard Replacement, Keyboard: Schritt 6, Bild 1 von 3 Acer Aspire E1-531-2438 Keyboard Replacement, Keyboard: Schritt 6, Bild 2 von 3 Acer Aspire E1-531-2438 Keyboard Replacement, Keyboard: Schritt 6, Bild 3 von 3
    • Using a Phillips #0 screwdriver, remove all of the following screws:
    • Fifteen 9mm screws
    • One 6mm screw
    • Three 3.5mm screws
  7. Acer Aspire E1-531-2438 Keyboard Replacement: Schritt 7, Bild 1 von 3 Acer Aspire E1-531-2438 Keyboard Replacement: Schritt 7, Bild 2 von 3 Acer Aspire E1-531-2438 Keyboard Replacement: Schritt 7, Bild 3 von 3
    • Remove the optical drive by sliding it out of its slot on the side of the laptop.
  8. Acer Aspire E1-531-2438 Keyboard Replacement: Schritt 8, Bild 1 von 2 Acer Aspire E1-531-2438 Keyboard Replacement: Schritt 8, Bild 2 von 2
    • Using a plastic opening tool, pry along the seam running the perimeter of the laptop to separate the bottom case from the palmrest assembly.
    • Flip the device over and open the laptop so that the keyboard is visible.
    • Lift up the palmrest assembly just far enough to access the connectors underneath.
  9. Acer Aspire E1-531-2438 Keyboard Replacement: Schritt 9, Bild 1 von 2 Acer Aspire E1-531-2438 Keyboard Replacement: Schritt 9, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using a pair of tweezers, disconnect the small white ribbon cable from the connector near the left side of the device.
    • Disconnect the large black ribbon cable near the middle of the device. Gently pull on the cable away from you.
  10. Acer Aspire E1-531-2438 Keyboard Replacement: Schritt 10, Bild 1 von 2 Acer Aspire E1-531-2438 Keyboard Replacement: Schritt 10, Bild 2 von 2
    • Lift and remove the palmrest assembly and the attached keyboard.
  11. Acer Aspire E1-531-2438 Keyboard Replacement: Schritt 11, Bild 1 von 3 Acer Aspire E1-531-2438 Keyboard Replacement: Schritt 11, Bild 2 von 3 Acer Aspire E1-531-2438 Keyboard Replacement: Schritt 11, Bild 3 von 3
    • Using a spudger, release the keyboard by prying at the indicated points.
    • Remove the keyboard from the palmrest assembly.
Abschluss
Jakob Rinkus
965 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team S8-G2, Bailey Spring 2019 Mitglied von UMass Dartmouth, Team S8-G2, Bailey Spring 2019
UMASSD-BAILEY-S19S8G2
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 1,837
