Zum Hauptinhalt wechseln
Acer Aspire E1-531-2438 RAM Replacement
Was du brauchst
  1. Acer Aspire E1-531-2438 RAM Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Aspire E1-531-2438 RAM Replacement, Battery: Schritt 1, Bild 2 von 2
    • Unplug and power down the device before removing the battery.
    • Turn the device over so the back side is facing up.
    • Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
    • Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
  2. Acer Aspire E1-531-2438 RAM Replacement: Schritt 2, Bild 1 von 1
    • Tilt the side of the battery closest to the orange latch upward.
    • Lift the battery up and out of the device.
  3. Acer Aspire E1-531-2438 RAM Replacement, RAM: Schritt 3, Bild 1 von 3 Acer Aspire E1-531-2438 RAM Replacement, RAM: Schritt 3, Bild 2 von 3 Acer Aspire E1-531-2438 RAM Replacement, RAM: Schritt 3, Bild 3 von 3
    • Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
    • Remove the access panel to expose the hard drive, WiFi chip, and RAM modules.
  4. Acer Aspire E1-531-2438 RAM Replacement: Schritt 4, Bild 1 von 3 Acer Aspire E1-531-2438 RAM Replacement: Schritt 4, Bild 2 von 3 Acer Aspire E1-531-2438 RAM Replacement: Schritt 4, Bild 3 von 3
    • Gently press outward on the two tabs that lock the RAM module in place.
    • Once the RAM module releases and flips up, gently pull the RAM module directly out of its socket.
Abschluss
Jakob Rinkus
965 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team S8-G2, Bailey Spring 2019 Mitglied von UMass Dartmouth, Team S8-G2, Bailey Spring 2019
UMASSD-BAILEY-S19S8G2
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 590
